milltek hi flow sports cat
  • stevieyid
    • Apr 2005
    • 2251
    Hi i was wondering if u need a special system to fit these on a s2 coupe or will they fit onto a standard exhaust? Need either to bypass the cats or get a better high flow one especially now as one has collapsed inside. Thanks for your help
  • Beetie
    • Oct 2003
    • 1517
    What year is the car? If its early enough i'd just bypass them......
    • stevieyid
      • Apr 2005
      • 2251
      its a 93 6 speed. Iwas thinking of buying the bypass pipes on ebay not sure if they would fit though thats why i looked at alternatives
      • Beetie
        • Oct 2003
        • 1517
        milltek make bypass pipes as i have them on mine......
        • stevieyid
          • Apr 2005
          • 2251
          hwo much are they? Do u no where u got them from? Only problem is i only have standard system except for the back box so would the bypass pipes or sprts cat fit on mine? What system do u have? Do u have any problems with mot or do u put them back on for the mot
          • Beetie
            • Oct 2003
            • 1517
            Mine fly's through the mot Its a milltek 2.5 system from cats back.
            Im pretty sure you can get the pipes from milltek direct, if you can find there website. Im not sure what the size of a standard system is, but im sure somebody can tell.....
              dodgy MOT tester! lol, anything after august 1992 shouldnt pass without cats.
              • 4WheelDrifter
                • Oct 2004
                • 5773
                • Country: Devon
                I seems to vary, dependant on make/model.
                SS
                • Beetie
                  • Oct 2003
                  • 1517
                  Like i said, mine fly's through....
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    A few bottles of Stella can help. BTDT.
                    SS
                    • Beetie
                      • Oct 2003
                      • 1517
                      Not if they are in my possesion......
                        Hmm seems they've change it slightly.
                        Taken from the MOT Testers website
                        7. Your vehicle has had its catalytic converter removed and replaced by a normal exhaust silencer but passes the emissions Test. Does it fail the MOT because it hasn't got a catalytic converter when it should have one?
                        a) No, if it passes the emissions part of the MOT that is acceptable.
                        • Beetie
                          • Oct 2003
                          • 1517
                          Caught yourself out there m8!
                          • stevieyid
                            • Apr 2005
                            • 2251
                            thats good news then. Does anyone no if the milltek bypass pipes or the scorpion bypass pipes would fit a standartd system. Cheers need to no before i buy some
                              Not really, ask Mihnea, it's impossible to map an ABY to pass an emissions test without cats.
