rs2 manifold performance question!!
  • tom
    • Dec 2004
    • 282
    is there any difference between rs2 and s2 ABY inlet manifold in performance or all it is it's just "powered by porsche"
    help urgently needed!!!
  • quattronutter
    • Jan 2005
    • 690
    basically the same part,apart from the porsche label of course..
    • tom
      • Dec 2004
      • 282
      so there is no difference between air flow etc?
        No difference apart from the Porsche logo.
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          Surely the extra bling is worth a few bhp.
          SS
          • Baldy
            • 469
            • Home: Sikkim Current: British Antarctic Territory
            I'm sure it will boost your ego if nothin else
            Nautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management The old Bus
            0-60 4.9
            1/4mile 13.5
              Only thing it will boost is the insurance premium
              • tom
                • Dec 2004
                • 282
                thanks for Your help,
                how does it look with outlet manifold? is rs2 manifold any better than s2?
                s2 and nothing else matters
                • Sweeper
                  • 1317
                  • Country: Latvia
                  tom: a bit better , don't crack so often and could add some extra HP
                  Vadim.
                  • Rusty
                    • 18953
                    RS2 EM is better as it is freer flowing. This mod has been used by many on here running more power. Other aftermarket ones are available for conversion to Garrett turbos AFAIK.
                    Apologies if you know any of the following...
                    Intercooler is bigger (longer).
                    Injectors are higher capacity.
                    Airbox has a larger inlet.
                    Downpipe is bigger diameter.
                    Cams are different and similar to 7a normally aspirated 2.3 20v.
                    I'll be corrected if I've missed anything or got anything wrong!
                    HTH
                    • porkkis
                      • 1994
                      HTH
                      Only exhaust cam is different and it's not similar to 7A except it's a 5cyl cam
                      Water pump is different
                      Cam pulley is different
                      ECU (MAP) is different
                      MAF is slightly different
                      • Audi Parts Guru
                        • 1317
                        I understand that the RS2 IM manifold has a slightly larger internal volume that the S2 unit
                        • porkkis
                          • 1994
                          I think the ABY and ADU is the same volume. I haven't measured these, but Marco says so. He's one of the guys that tend to cut the BS and bring out the facts. I mean that I think we can rely on his info.
                            Check S2central for a big list: http://www.s2central.net/tuning_02.html
                            • audiman
                              • 4827
                              cats are different too. rs2 uses metal cats and not ceramic ones.
                              Tom C - www.rcmr.co.uk
                              Audi UR Quattro
                              Audi 100 C3 2.0 5 cyl 115ps
                              Audi B5 RS4 645ps 911nm
