Had to replace turbo to cat downpipe with another standard item. Cats seem to sit much lower to the ground than originally ( but are attached at their front brackets correctly ) and I have seen other S2 coupes where the exhaust system is all but hidden from most angles away from the car. Clearance now means I have to avoid roads with the "individual" type speed humps. Can anything be done apart from custom turbo back systems ?
Standard exhaust clearance (?)
Can you repair your old one and swap back??? Just a thought.
I have recently changed my CATs back to Bypass pipes and have noticed the exhaust grounding where previously it never did. I know this is not the same case as yours but sometimes the way it is fitted together can make a difference..,
Just my 2p's worth.
Cheers,
SteveThe Perfectionist
