where to put?
  • stevieyid
    • Apr 2005
    • 2251
    where to put?
    Hi got a boost gauge from a mate of mine but struggling to find a suitable place to put it. Where have u lot got yours? I want to keep all oil temp, volt meter and oil pressure gauge so where can i put the boost gauge. Cheers
    3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips (just need the RS2 Airbox)
  • Baldy
    • 469
    • Home: Sikkim Current: British Antarctic Territory
    the usual place people mount their guage tends to be in one of the central air vents and others mount it in a pod on the steering column see jamo's thread jamo's guage
    Nautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management The old Bus
    0-60 4.9
    1/4mile 13.5
    • s2driveruk
      • 12696
      centre pod for me, though you'll probably need to pop out the vent and mage a suitable blanking plate for it to mount too. Also, if you want it flush with the other vents you might find the pip running off the back with not allw the vent to be openned or closed fully.
      HTH,
      David
      1992 3b S2 Coupe
      • S2 Ant
        • 3682
        Ah so im not the only person that cant use the centre vent properly then
        Ant
        2011 Kawasaki Z1000
        • PhilS2R
          • Sep 2003
          • 116
          • Country: France
          I prefere this :
          God forgives...... Me not....
          and
          If you disturbs the dog...
          It will puff out you the hand !!!
          Pitbull Proverb
          • porkkis
            • 1994
            If you have time to watch the low mounted boost gauge then your car is too slow. IMHO. It's the worst place.
            • PhilS2R
              • Sep 2003
              • 116
              • Country: France
              on the top the first time I put on down now is on top ;-)
              and
              Pitbull Proverb
                See Martynf's install http://www.s2forum.com/forum/showthr...ht=boost+gauge
                IMHO 2nd best place after mine
                • HPmuirt
                  S2Forum April Fool
                  • Apr 2005
                  • 3014
                  Nah mate, 2nd & 3rd place after mine
                  See my pic in this link
                  Fitted in 10 mins
                  No hacking the car to bits
                  No obstructed air vents
                  Cheers n
                  Si
                  Subtle mods here and there
                  2011 A5 3.0 TDi - Lava Grey
                    You must be a short ars*!
                    No way would i be able to see that during normal driving
                    • HPmuirt
                      S2Forum April Fool
                      • Apr 2005
                      • 3014
                      Yup, a miniscule 6' 2" matey
                      You may find that if you are shorter, you could not see this through the wheel, but having the seat further back makes it perfect - although you will now have to glue blocks to your feet to reach the pedals
                      Cheers n
                      Si
