the door trim is a likely suspect. there is a small triangle on the front of the door trimit is located by a small peg or prong. This sticks in a hole to locate it correctly. if it is missing you need to locate it properly. I used a screw all the way through.
If the car has had a new windscreen then the fitter may not have replaced the aluminium gutter trim correctly.
It needs to be riveted correctly. Water can run down the inside of the trim and wet the carpet.
