Instrument Cluster
  • Erikb
    • Jul 2004
    • 648
    Instrument Cluster
    Hi all,
    I got my instrument cluster out, and saw that the glass (plastic see throug) had a few scratches and was broken on several places. Does someone know if this can be bought separately or do you have to buy a complete unit? Further I noticed that my time LCD display is not clear anymore, can this one also separately be displaced?
    thanx,
    Erik
    Getting everything sorted out for my 5++ hp project
  • Sidspud
    • 1223
    • Home: Scotland Current: United Nations
    As far as I know the clear plastic is bonded onto the rear of the cluster housing and must be bought complete. Go to a breakers though as any cluster from an 80 (or 90) should do. Just swap your clocks into the new housing.
    I think the clock is part of the rev counter, but if not, then it might available from a breakers also
    ex '93 Avant owner
    • Erikb
      • Jul 2004
      • 648
      Thanks Sidspud!
      I hoped there was a way to remove the cover and just buy a new clear one.
      P.S. I saw your thread on the aluminum rings on the dials, looks really good. May I ask what you pay for it?
      • Jas11n
        • 5067
        The digital clock can be changed on it's own.
        2001 Avus Silver B5 RS4.
        1995 S2 Coupe - sold (sniff)
        • rotoryboy
          • May 2004
          • 3281
          The parts in question seem to be all seperate, You will have to wait for one of the dealer boys to reply to see if they are available though
          Mark
          Race Clio RS197
          S2 Coupe ABY (Green) - RIP
          S2 Coupe ABY (Blue) - Sold
          • Erikb
            • Jul 2004
            • 648
            Thanks all, that really helped me. I hope they are available.
            So you all sure that the plastic cover cant be bought on its own?
            • Jas11n
              • 5067
              Plastic cover isn't available seperate Erik.
              With regards the digital clock.
              There are two versions of instrument panels used in the B3/B4 Audi's. VDO and UN4. (S2's and most 5/6 cylinder Audi's used VDO, UN4's were used in 2.0 8/16v 4 cylinder models)
              I got a digital clock from a UN4 cluster to fit in a VDO cluster. So it should work the other way round.
              What I'm trying to say is that you should be able to use a digital clock from any other 80/90/Coupe/Avant or cabriolet.
              • HPmuirt
                S2Forum April Fool
                • Apr 2005
                • 3014
                Jas, you gotta do summut about your sig....it's taking over
                Cheers n
                Simple Si
                Subtle mods here and there
                2011 A5 3.0 TDi - Lava Grey
                • Jas11n
                  • 5067
                  Cheers n
                  Simple Si
                  Done
                  It's only cos I've got a lot to say, or should that be "full of sh*t"
                  • pastures16
                    • 2058
                    ok while where on the clock subject why does mine now and again reset its self overnight back to 12.00
                    94 s2 avant
                    aoc member 1116
                    • Jas11n
                      • 5067
                      Dirty contacts on the back of the LCD display.
                      BTDT.
