Speedo not working. Help!
  • tobodestroyer
    • Dec 2005
    • 174
    Hi,
    Yesterday I removed the instrument cluster in order to replace my ignition barrel. Now my speedo doesn't work. Did I forget to reconnect something or is there a dodgy connection somewhere? Is the yellow connector behind the speedo dial the one responsible for the speedo working properly or is the blue one lower down? Has anyone else had a similar problem and managed to fix it?
    My car is a 94 S2 Avant ABY.
    Any ideas?
  • ian_jemo
    • Aug 2004
    • 284
    Hiya
    If it was working before you taken it out, it is probably just one of the connectors has come loss. When putting it back into the car some of the connectors can come loss if not put in right as you have to place it in at an angle.
    Is it just the speedo dial that doesn't work?
    1991 S2 3b, Samco Hoses, RS2 IC, 18'' RS6 Wheels, Forge Dump Valve, Scorpion Exhaust System, Decatted, MRC Remap
    • tobodestroyer
      • Dec 2005
      • 174
      No mileometer either.
      • ian_jemo
        • Aug 2004
        • 284
        I'm sure its a loss connection. You'll have to take it all out and try again. Obviously don't fix all in place until fixed
