91 Coupe Quatro Dashboard.
  • AnotherProjectCar
    • Oct 2018
    • 3
    Hello dear forum friends. I am new to this. I have a 91 Coupe Quattro US model that needs a dashboard. My car has the wood trim above the glove box and climate control. I found a Dash from a 90 coupe without the wood trim. does anyone know if the dashboards are the same otherwise and can the wood trim be fitted to the 90 dash.
  • LSG
    • May 2010
    • 897
    Sorry I can't help with your question. to the forum and good luck with sorting the car kind regards Lynn.
    • sjw185
      • 1175
      Think it will be the same. I fitted coupe trim to a 80q sedan without trim.
      Dash had a quattro badge just drilled the 6 holes and attached no bother.
      See really bad photo from old nokia
      This gallery has 1 photos.
      • _ShurikeN
        • Mar 2010
        • 733
        • Country: Russian Federation
        I can confirm that, it was done by me too on a lhd car.
        • PRY4SNO
          • 767
          Yeah you should be fine, people swap dashboards regularly.
          2013 Touareg TDI /// #farmenwagen
          • varia
            • 821
            • Current: United States
            every CQ in the usa had wood inserts on the dash, above the glovebox. a dash from a b3 80/90 without the wood trim will work.
