Opening Rear Windows
  • david1980
    • May 2014
    • 1028
    Myself and one of my friends are looking to 3d print the small raised up section for the parcel shelf supports to replace some missing ones from a set I bought.
    Does anyone have some picture and even better would be dimensions for them? It would be good to get as much information as possible for a cad file that could be on here incase anyone else requires them.
  • david1980
    • May 2014
    • 1028
    • david1980
      • May 2014
      • 1028
      anyone?
      • LSG
        • May 2010
        • 897
        Alright David I have two sets of rear opening windows in the lock up. I could pop and have a look see what size things are. If this would help.
        • LHD_Kid
          • May 2006
          • 3697
          You really need to remove one of the covers and 3D scan it....
          • 4WDrifter
            • Nov 2012
            • 1251
            Is it this bit you’re referring to?
            This gallery has 1 photos.
            1996 S2 ABY Coupe silver
            2003 S3 8L dolphin grey
            2014 RS4 B8 prism silver
              /\ This. There is some complex geometry going on there
              • david1980
                • May 2014
                • 1028
                sorry I've only just seen the replies. 4wdrifter, yes its that bit.
                I don't have the covers to scan, the seller didn't have them with the window set
                • 4WDrifter
                  • Nov 2012
                  • 1251
                  I might be able to take an impression in polyvinyl silicone of mine and then get a plaster of paris model made of it which I may be able to get scanned. I’ll try and see what comes of it.
                  • david1980
                    • May 2014
                    • 1028
                    That sounds very interesting. Its just a shame they are so fragile, i've heard of a few people over the years that have needed them.
                    • LHD_Kid
                      • May 2006
                      • 3697
                      They use the standard rear trims, but have a square cut out, the cover is then glued over the top. It's the square piece cut out that makes them fragile. Easy enough to make from a standard trim, if you can get a cover piece to copy...
                      Good luck!
                      • david1980
                        • May 2014
                        • 1028
                        Yes if I can get the cover piece dimensions/etc I will get them 3d printed by my friend in Flitwick. He has already offered to copy other bits that are getting hard to get like the bumper grills
                        • 4WDrifter
                          • Nov 2012
                          • 1251
                          I’m hoping to have a go at this tomorrow. Does your friend scan the item and then print it?
                          • 4WDrifter
                            • Nov 2012
                            • 1251
                            B48439E4-1AB1-48D0-A1D6-D81B9119A2A2.jpeg6EE05D3F-C584-4A64-B05A-EFC3F7E70D04.jpeg16FE553A-22EA-4476-B2B2-79F4E39DE97E.jpegBF1F14B7-C216-47F9-9D55-445EEB28C08A.jpeg9FB8D692-F3CE-4015-89F3-F8CF31FF9013.jpeg Managed this today. Here are some photos. I’ll get my mate now to pour acrylic into the mould and I will send you the copy.
                            • david1980
                              • May 2014
                              • 1028
                              Wow not seen that done before! I will send the pictures to my friend and see what he says about it but I'm sure he will have no problems giving that a go!
