Drivers Door Trim Removal
  • ianmt
    • 130
    Help Please
    The electric window on the drivers side has stpped working! I heard a snapping noise and then just a motor noise, window in open position, but will stay up if manually pulled up.
    My question is, how does the interior trim come off to gain access to the motor assembly etc.?
    Any pointers would be appreciated. Car is a 91 3B Coupe.
    Ian
    '91 3B Coupe
  • Crawford_S2
    • 1555
    There was a recent thread on this, search button is your friend!
    Ragusa Coupe gone!
    • Crawford_S2
      • 1555
      http://www.s2forum.com/forum/showthr...ight=door+trim This is two old thread stuck together, should help.
      Ragusa Coupe gone!
      • ianmt
        • 130
        Thanks Crawford, I couldnt find myself, reaaly appreciate your help.
        Ian
        '91 3B Coupe
        • Ross
          • Aug 2005
          • 3399
          I did this one recently, was an Avant though, it's actually simpler than I expected!
          The guide linked to looks good, just to mention that you need to pull the door card UP and off once all the screws are out. I was first trying to pull it out and up and snapped some of the tabs that hold it to the door... fortunately, Loctite superglue really does what it says on the tin
