There's no cog on the output flange, just a plastic ring with a magnet in it. It may be possible to change it without removing the gearbox, by removing the left side of the front diff casing.
When mine started playing up it was the same time the clutch did and I first off found that by going round left handers quick the speedo would bounce into working then die, eventually it just started working again so never got to find out the problem.
