Harnesses
    Harnesses
    Has anyone fitted harnesses to their S2? I'm thinking about it for track days using the rear seatbelt bolt holes but not too sure whether I want to drill 4 holes in the floor and carpet to fit the front belts in place. Any other ideas BTDTs?
    Next question, are there any other manufacturers other than Recaro and Corbeau who make subframes to fit the s2?
    • s2driveruk
      • 12696
      didn't know Corbeau did them...
      1992 3b S2 Coupe
      • Keeper of The Kitten
        • Dec 2003
        • 2317
        One thing I will say, strictly speaking, you shouldn't mount the shoulder straps of a race harness much lower than 4" (100mm) below the shoulder level of the driver, to prevent spinal compression if subjected to a heavy loading.
        Mostly, harnesses are mounted to a crossbar in a cage or to a seatback bulkhead in a tub or safety cell.
        I know a lot of people mount to the floor a long distance behind the driver but it's not really the right way to do it.
        Martin Cutting
          Hmmmm. I was aware of that from fitting instructions from a friend's car. Do seats with the harness guides (such as Recaro Speeds ) not provide some support for the harnesses / compression? A rear cross brace isn't a possibility at present, unless anyone does a bolt-in item and then you're putting your trust in the shear loading of a few 8-10mm bolts... not ideal.
            Indeed they do linky1 linky2
            There are always a few pairs of Corbeau Forza fixed buckets on Ebay fo 5/8th of FA, they're basic but supportive, a friend has them in his Scirocco track car. Other Corbeau seats, like the speed replicas, look a little cheaper and I'd prefer some secondhand Recaros for similar money.
              Corbeau Buckets on t'bay
              • s2driveruk
                • 12696
                hmmmm recaros - i think i might have bagged a pair myself :mischeif:
                1992 3b S2 Coupe
                  Speeds from a 'teg' type R or Mitsubishi evo? Or some less race-style ones?
                  • s2driveruk
                    • 12696
                    RS2 type....just not from an Rs2
                    1992 3b S2 Coupe
