Trip computer loom.....
    Woop! won some s2 clocks on ebay earlier.... i have a control stalk and loom.. but the connectors seem to have been cut off the loom where it ends up uder the dash by the diagnostic port..... there are 3 wires ending up there,
    * yellow
    * grey with yellow stripe
    * white with grey stripe
    Am i correct in thinking the yellow connects to the yellow connector under the dash. and the other two are unused?
    cheers
  • mcandmar
    • Apr 2004
    • 5118
    Pic here help? http://www.s2forum.com/forum/showthr...light=computer
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • mcandmar
      • Apr 2004
      • 5118
      Colours don’t match
      Yellow is the ecu reading for fuel rate. I think it’s actually the maf signal.
        Weird!
        I've got the right control and computer plugs, just the wires coming off for the ECU are different
        Heres my loom
        but i have a single yellow to a black plug, then a white and grey coming off it
        • mcandmar
          • Apr 2004
          • 5118
          Ahh ok i just read my post again, the red plug isnt used only the small yellow one. Find the other end of the yellow under the dash (i had a connector to match my loom) and see does that work.
          Mark.
            I'll give it a bash when my clocks turn up - hoep it does, otherwise i'll have to find another bloody loom
            Cheers for your help again Mark
            Just musing, but you mentioned in your intsall thread the URS4 has boost readout on the Trip - it that potentially what the red connector is for i wonder?
            • Jas11n
              • 5067
              Try this thread >> here
              Has a good link, (pdf, but in german) and some pinout info.
              2001 Avus Silver B5 RS4.
              1995 S2 Coupe - sold (sniff)
                got it all hooked up - getting no feed from the ECU for fuel i don't think.... its showing last recorded mpg (as expected) but no change with revs etc... can't move the car as its up on axle stands, but the manual suggests it should show a really high figure if revved from stationary
                time for a proper loom me thinks
                • 80Quattro
                  • Sep 2006
                  • 420
                  • Home: United Kingdom Current: New Zealand
                  You have to drive 30m before it will register an mpg, all it says in the manual is it 'may' show a very high reading when depressing the accelerator while stationary. I would wait until you can drive the car before you decide to replace the loom.
                  92 Audi 80 Quattro => RS2 Saloon!
                  98 TVR Cerbera 4.5
                  63 Austin Mini Super Deluxe (turbocharged)
                  69 Austin Mini Cooper
                  71 MGB GT
                  75 Daimler Vanden Plas 4.2L
                  04 Kawasaki GPX250
                  96 Subaru Legacy GT-B
                  • mcandmar
                    • Apr 2004
                    • 5118
                    Yep dont work when stationary. It usually gives the last readout, so sometimes when you stop it will claim 200mpg!
                      ah ok, well i've bought one now
                      Not to worry they are wellsought after i'll just make sure both work then sell one.... will be a control stalk with rear wash wipe to go with it, perhaps someone on here will save me the hassle of going on fleabay :lol
                      • Acidburn
                        • 13459
                        I've just seperated the trip computer loom from a spare rs2 loom I had sitting around, anyone know where the yellow wire would connect to on a 10v saloon, i've had a look at the plug mentioned above and the two other colour wires are there but on the other side the only wire which is spare is a green/brown iirc.
                        • Jas11n
                          • 5067
                          2226cc 10v (KV) ??
                          • Nuvo
                            • Nov 2003
                            • 3826
                            I think its pin 30 for K-jet.
                            • Acidburn
                              • 13459
                              Just checked the logbook which handily turned up this morning its a KV.
                              @nuvo - how do I find pin 30? or is it marked on the plugs? (I can check this on the spare rs2 loom)
