Avant inner door handles front/rear
  • Acidburn
    • 13459
    Just wondering will the rear door handles for an avant fit the front?
    part codes are
    8a0 837 020 (right hand side front)
    8a0 837 020 A (right hand side rear)
    tbh I can't see no difference from the pictures straight away, if anyone knows if that these will fit
    Rear one is on the left, all I can see being any different is that the tab looks longer and there is a bit of an insert at the front, tbh tho from what i've heard all I need to do is swap the innards over?
  • Nuvo
    • Nov 2003
    • 3826
    They are the same provided they rear don't have electric window switches. The picture you added shows this clearly. You can swap the handles over easily enough.
    • AlexS2CQ
      • 47
      • Home: Germany
      RS2 rear door handles in coupe LHD door panels.
      Actually just the same as for avant.
      Fits "plug n play" - if you only cut out a small piece in the door cover for the switch.
      (The switch is for central locking.)
      Regards,
      Alex
      My B4 Avant
      My S2
      My Cabrio
      • Nuvo
        • Nov 2003
        • 3826
        Double post. Please delete.
        • Nuvo
          • Nov 2003
          • 3826
          Alex, I did realise it was for central locking, I would have thought it was for rear electric windows (this is certainly true for UK cars). I'm pretty sure the Avant rears are too big for an RHD S2 Coupe.
          Nice door builds, what is the little red thing at the bottom left hand corner of the door panel?
          • s20ale
            • Aug 2004
            • 476
            Yeh nice doors did you do the speaker pods yourself. ?
            • AlexS2CQ
              • 47
              • Home: Germany
              Hello Nuvo!
              You´re right:
              In normal case the switch in the door handle is for the rear electical window.
              But i (and many other mates too) took an A8 central locking switch.
              The little red lamp is a door light -
              Because of parking near the street and in fact of oversized coupe doors,
              it´s better to warn other cars behind by night that the door is open.
              @ s20ale:
              The speaker panels were made by an ebaymember aka "scully".
              But i had to make some adapting works too, because they didn´t fit at all.
              Here you can find any more:
              Scolling down the thread you will see pictures of the panels.
              My post is the 69th.
              Cheers,
              Alex
              My B4 Avant
              My S2
              My Cabrio
              • Nuvo
                • Nov 2003
                • 3826
                Hi Alex, do you have any more details or pics of the parts you used for the red parking lamp, the central locking switch and of course the door buids too?
                In fact any details about the modifications you have made to you car would be very interesting to learn about.
