Battery help
  • brm180
    • Jul 2004
    • 158
    Battery help
    Hi guys, quite embaressed asking this question but how do you raise the rear bench seat in order to get to battery.
    A sheepish thanks brm180
  • Nuvo
    • Nov 2003
    • 3826
    There are two phillips screws just below the seat on the carpet. Undo these and remove the bench. Easy peasy.
    • brm180
      • Jul 2004
      • 158
      battery
      Thanks, i did actually see them but wasn't sure if there was a hinge or similiar.
      Thanks...
      brm180
      • Nuvo
        • Nov 2003
        • 3826
        The Avant has hinges the coupe doesn't IIRC.
        • gnutz2
          • Aug 2006
          • 928
          Avant has the battery in the boot
          The ONLY S2 Golf!
          http://www.s2forum.com/forum/showthread.php?t=19402
          10.42@138mph
          https://m.youtube.com/watch?v=0wnkkOfFpXg
          • Nuvo
            • Nov 2003
            • 3826
            That's right, I was just mentioning the differences of the rear bench seats between the two.
            • amanda
              Account Disabled
              • Nov 2006
              • 524
              Hmmmmm my avant doesn't have the battery in the boot so no need to move the child seats
              • Jas11n
                • 5067
                You haven't got an S2 avant though
                2001 Avus Silver B5 RS4.
                1995 S2 Coupe - sold (sniff)
                • Knight Rider S4
                  • 3541
                  You had to much sauce Amanda
                  93 S2 Avant Parting
                  91 URQ RR
                  02 A4 tdi Avant
                  • ericd
                    • Nov 2003
                    • 1240
                    I'm about to change over the battery (can confirm it's the original been there since 1995), everything nut/bolt still with it's green paint spot, never really noticed before, but old batteries don't have handles to lift them out and the clearance either side looks about 2mm, and even my petite hands struggle to get in , I removed the top bolt and clamp at the rear, does the lower clamp with earth cable attached need to come out to let the battery free, cause I can't see otherwise how its gonna come oot ?
                    Anybody had similar problems
                    cheers
                    • ericd
                      • Nov 2003
                      • 1240
                      anybody ?
                        I did mine a few years back Eric... Sure enough was a squeeze on the fingers but can't recall anything particularly nasty about swapping in a new one. There was indeed a clamp at the bottom though - pretty sure - that needs to come off !
                        • ericd
                          • Nov 2003
                          • 1240
                          cheers, I've been at it for about an hour , it just that the clamp looks like its stuck down and won't move much either way even if i take the earth cable out
                          • ericd
                            • Nov 2003
                            • 1240
                            just my luck now the 13mm bolt holding it doesn't want to come out..
                            • ericd
                              • Nov 2003
                              • 1240
                              got the bolt out, still no joy, looks like you need to lift it completely level, so it doesn't touch the sides, and the dead weight means its pretty difficult as the only things to get hold off are the terminals, spent about an hour "hands-on" trying to free it , but no luck, tried to put a cable cradle under one corner but clearances aren't enough, real PITA to be honest
                              tn_DSCF0660.jpg this was the bolt that held the earth lead to battery, you cant really see in the pic but it's spot welded or similar to the battery tray
                              tn_DSCF0661.jpg pretty tight clearance, remembering that there's alip at the bottom of the battery
