i take it all back , sorry im worng. I remembered today that i originally modded the runners on the g60 recaros to fit my 90 20v the tx them into the coupe. Series 2's are the same as mk1/2 golf, rado and roco.Apologies, my mistake
Gav
Subframe for Recaro seat
Just got another reply from Capital Seating. Apparently they still make the subframes for the turbo quattro, the 100, 200, and V8. Are any of these similiar to the Coupe?Leave a comment:
Are the G60 runners different widths? Really not bothered about height.Leave a comment:
Interesting, you wnat them low so you can actually fit in the car without hitting you head
Scirocco frames are differnent, too narrow.
mk1/2's corrado's are the same, mk3 and late mk1 cab are completely different. I put a pair of editon one recaros from a mk2 g60 in my old 20vcq and they bolted straight in , but they were a little low. My wife has recaros in her corrado, i can meaure them if you like to make sure
GavLeave a comment:
yeah i tried my mk2 gti recaros in my cq with no sucess, as Alex said too wide, possibly mk3 tho....i'm sure something will be similar?!?! what about Acidburn? he got somone to do his recaros...seems very good...
AntLeave a comment:
This is what i thought.Don't think this is correct.
Mk 1 and 2 Golfs are the same as each other, although Mk 1s have their adjustment handle for sliding backwards and forwards on the outer side of the seat and the Mk 2s on the inner side of the seats, the B4 platform takes a wider seat base.
i.e. the two rear legs of the seat are wider on the B4s than a Mk 1 / 2 Golf.
BTDT.
Kind regards.
Thanks for the suggestion anyway though, i think the easiest way if i can't find a second hand one would be to weld my own using an old OEM seat base.Leave a comment:
Gavs20v,
BTDT.
Kind regards.Leave a comment:
mk2 golf and corrado runners are the same as 80/90 just check the heaights though as theyre differentLeave a comment:
Try
Demon Tweeks just in case?
Got mine there about 9 months ago. Its for a mk 2 Recaro out of a Golf Rallye.
Any port in a storm.....
Good luck.Leave a comment:
Capital seating just got back to me, they said the subframes have been discontinued
I guess i'll be making one myself!Leave a comment:
