Accelerator Pedal
  • Ian Simmonds
    • Jun 2005
    • 2858
    Accelerator Pedal
    Don’t laugh…
    I’ve broken it…
    Well, the flappy plastic bit that is spring loaded. Any idea to the following questions –
    1 – is it an MOT failure with it missing?
    2 – how does it come apart?
    3 – Is there an alternative pedal cover that can be fitted?
    Many thanks
    Ian
    (PS – I wasn’t thrashing it, honest).
    93 MTMS2 Avant
    Search the forum - this isn't the 1st time its happened... Few fixes have been documented.
      • 12431
      I didnt bother with spring bit and cut it off the grip filled the plastic bit back onto the pedal after scoring the pedal and plastic bit to make it stick and its been fine since. I didnt like the spring loaded pedal anyway.
      • CoupeWannabeS2
        • 403
        Recently fixed mine - same problem. Hadnt got round to fixing it since buying the car a couple of years ago. After seeing this thread I used no-more-nails. The plastic pedal is now firmly attached. Rather than laying in the door card pocket !
        • iain1067
          • 984
          as a temporary fix cable tie it
          • Fat Audi 80
            • 10547
            P.S. No its not an MOT failure, but I think you may know that already based on your other recent post!
            The Perfectionist
            • pixsaudisex2
              • Sep 2004
              • 3110
              i tell ya a cable tie or two an its like oe, no no its better it even feels better,,
              • anton
                • Jan 2005
                • 802
                lol dont let Fatty hear you say that! bad things will happen
                i need to re-fix the acc pedel on mine too....just need to buy the right adhesive,my original araldite idea didnt work out lol, i'll give no-more nails a whirl.....
                Ant
                91' Coupe quattro 20v - project
                KW V2s and other goodies
                now gone
                03' BMW 330CI - Sold
                08' A5 Coupe 3.0l tdi quattro - Sold
                57' BMW 525d M Sport Touring
                • Nj
                  • Jan 2007
                  • 3420
                  • Home: Scotland Current: Finland
                  this reply may be a bit late but I just noticed it
                  1 - no
                  2 if the flappy bit breaks it's easiest just to replace the whole thing. It's fixed on pretty permanently. reach in and grab the plastic fulcrum piece that the pedal arm pivots over. tug the whole thing towards you and it will pop out complete. the opposite end from the bit you stick your foot on has a notch cut in it and the throttle cable end fits in here. anyone breaking a coupe should be able to send you the full pedal and it's not too bad to swap them. Only issue i've found is the throttle cable runs over a pulley before passing through the bulkhead so it's best if you take the old pedal out, keep tension on the cable and transfer it immediately to the new pedal before you push the fulcrum part into place.
                  3- as the guys have said you can stick something into place but there's not much backing there to drill through if you wanted to drill and bolt on a replacement pedal.
                  now here's where you come back and say you've just done that and i'm rambling to myself
                  1990 CQ20v
                  • Ian Simmonds
                    • Jun 2005
                    • 2858
                    1 - no
                    You're going to kill me.....
                    I've just done that (3 - the original pedal cover), and it's passed it's MOT....
                    There was a slight technical issue just after the MOT, but I won't digress...
                    93 MTMS2 Avant
                    • Nj
                      • Jan 2007
                      • 3420
                      haha. excellent. half the coupes i've had have had the plastic cover of the accelerator totally missing. i'm getting used to the swap over process
                      1990 CQ20v
