UrS6 steering wheel to UrS4 conversion DIY pdf
    This is for converting a UrS4/early UrS6 four spoke airbag steering wheel to a later UrS6 three spoke sport style air bag steering wheel. It is NOT necessary for the later style C4 A6 four spoke steering wheel - that should be plug and play.
    There are three methods to convert the UrS6 clockspring to make it cancel the UrS4 signal lights. I have used Method 1. I developed Method 2 and did a conversion with that. I then developed Method 3 but ran out of steering wheels to convert so Steve Y. an American UrS enthusiast completed Method 3 and wrote up the DIY. He did a bit more work than absolutely necessary but it certainly works if you complete the conversion as described.
    See the pdf attached.
    Enjoy (and be careful with the airbags).
  • Ruffiano
    • Sep 2007
    • 1458
    Thanks!
    and that shift knob in the last picture is very sexy.
    • hermanio
      • Jan 2009
      • 805
      has anyone done this conversion in a urs4 without tele and tilt livers ? im trying to fit a 3 spoke airbag steeringwheel in my urs4 but the urs6 airbag steeringwheel covers wont fit.
      5 Cylinder Freak
        IIRC, you don't need new leavers, just the UrS6 leaver knobs. I think you can get away with re-using the one on the left side.
        • hermanio
          • Jan 2009
          • 805
          my problem is that i cant use the steeringcovers from an urs6 on my urs4, what i think i need are steeringcovers from an urs6 without tilt levers but i think they dont excist
          5 Cylinder Freak
          • DamianURS4
            • May 2010
            • 406
            can you shed any light on the sexy boost guage holder-setup you have below the ashtray....?
              I am confused. Everyone who has done this conversion on an UrS4 has used the top and bottom UrS6 (or C4 A6) steering column covers. Is there something about your UrS4 that this won't work? You do have to change the cancelling ring with slip ring (i.e. clock spring) from UrS4 to UrS6 (C4 A6) style (Item 2, 543 D below). Then there should be no problems with the UrS6 (C4 A6) steering column covers.
              • hermanio
                • Jan 2009
                • 805
                i think the steering collum is different in from a car with tilt leavers, the lower cover i can fit, but the top one doenst fit because there is not enough space, i seems to be the steering wheel is to close to the dash, i will look for a picture to make it clear
                5 Cylinder Freak
                • shellah
                  • 28
                  • Country: Poland
                  next good solution :-)
                    Not seen this before - nice one - bit risky with the old dremel if you botch it and ruin both wheels though - ouch - steady hand required !
                    • hermanio
                      • Jan 2009
                      • 805
                      has anyone done this conversion in an urs4 without height adjustment ?
                      5 Cylinder Freak
