replacement switches and other questions
  • Taffy
    • Jun 2005
    • 101
    • Home: Wales Current: United Kingdom
    Replacement switches..
    Having not seen or been in any other S2s I'm confused about the central switches and other things , so I'd like to ask a few questions...
    1) Are they all supposed to be rocker switches or are they supposed to stay repressed when you press them?
    2) What's the difference with the Heated rear window switch I apparently need
    4A0941503C01C
    Is it something to do with the switch also powering the heated door mirrors and water jets?
    3) Any one know how to get off the centre console to get at the bulbs for the thermostat knoba and the gauges below?
    4) Replacing the electric window switches and mirror moving jobbie thing, easy job? Can't see nay screws but am loathe to go at it with a screwdriver...
    5) last question - (exterior question so apologies) I have a 3b S2, can I just use a replacement drivers side wing from any coupe?
    thanks in advance
    T
  • ronierogers
    • May 2011
    • 21
    i could only answer the 4th question. to be honest i am really looking for window switch until i landed on this page. this is already the second time that i will be repairing my on window switch so i can say that it is a simple DIY thing. if you need diagram i have some. just ask what you need if ever you visit again this thread. sorry for diggin up guys
    • Skull
      • 3506
      • Country: Slovenia
      1) some stay in, some stay out
      2) there are 2 versions, one normal, one with 10min time automatic turnoff, recognizable by its lenght and it stays out, all of them power also el. mirrors and jets
      5) yes you can
      3 and 4 are long answers, im in a hurry...
      Audi Quattro WR
      • benntenn67
        • Jun 2009
        • 859
        4) Remove the armrest from the door - the switch/control "thingy" is then easy to change
        Audi S2 Coupe 1995
        VW Passat GL5 (hatch) 1986
        Carrera Subway 8
