Aux Dials
  • Emirateslad
    • Apr 2010
    • 33
    Aux Dials
    Hi Guys
    Does anyone know how to split the centre aux dials. I purchased new white background as original one peeling. I have mangaged to get the centre consol out, pretty straight forward and now I have the bad dial removed, but I cannot see where I can disassamble without damaging the dial.
    You have to carefully prise off the bezel using a flat bladed screwdriver... no easy fix there I'm afraid. Just take your time, it'll take a while to do it but the more care you take, the better the end result.
    When putting the bezels back on, I just put an indent every 5mm or so, it's all hidden by the trim when you put it all back together.
    • Emirateslad
      • Apr 2010
      • 33
      Thanks Rusty, I see what you mean by tricky, and without causing to much damage. Want to get it done before the footie starts.
      Ticketyboo
      • Emirateslad
        • Apr 2010
        • 33
        What about the needle itself? does that just pull off?
          Yes, be careful though. If you have some fingernails then that will help, otherwise a teaspoon or small fork can be used as a lever.
          Before you remove the dials, take a clear picture of each gauge so that you know where the needles sit, they're not on the 0 point when stationary but about 5mm off.
          • Emirateslad
            • Apr 2010
            • 33
            AndyC,
            Thanks to all, job done. Now I have to refit the centre consol.
              Great stuff, hopefully no one will even notice all your hard work
