Trim removal
  • s2avant95M
    • 1217
    • Home: England Current: United States
    Trim removal
    Finally got hold of some carbon trim to replace my wood trim. I have searched the forum for a BTDT, but cannot find one. If anyone could give me a few pointers i would appreciate it.
    Tim
    1995 S2 Avant, ruby red - ** SOLD TO ROSS **
    Golf Rallye G60 ** SOLD **
    Golf MK2 Oaky with R32 engine
    Audi A6 Avant 1.9 TDi 130
    Golf MK2 8v Race car
  • rotoryboy
    • May 2004
    • 3281
    You will have to remove the door cards. Then you will be able to see easily how they are removed. As for the one on the dash if you open the glove box and look/feel behind you will find 3 (IIRC) pins with locking washers. Gently remove these washers and the panel will just pull off.
    Mark
    Mark
    Race Clio RS197
    S2 Coupe ABY (Green) - RIP
    S2 Coupe ABY (Blue) - Sold
    • s2avant95M
      • 1217
      Mark
      thanks mark, are the doors cards easy to remove, ie are the screws visible?
      Tim
      • rotoryboy
        • May 2004
        • 3281
        It is easy enough, but take your time and don't break any clips. Have a read of this thread it will help you. Good Luck.
        Door Card Removal
        Mark
        Race Clio RS197
        • Sidspud
          • 1223
          • Home: Scotland Current: United Nations
          This thread will tell you how to get the door cars off. Then its just a matter of unclipping the trim and swapping it over.
          The dash piece is actually held on with 6 washers. Its a bit of a back breaking job. I found myself lying upside down on the passenger seat with my feat through the sunroof! Elegant as always.
          You need to remove the glove box. If you have cruise control then its a lot easier if you remove the module situated up behind the trim, but it is possible to remove the washers with it still in place. I used a small terminal screwdriver and a pair of needle pliers to basically rip the washers off. Once all 6 are off the trim should just pull off the front. Straighten out your washers and refit the new trim. Easy peasy, lemon squeezy!
          Now all you have to do is get yourself out of the car - easier said than done.
          ex '93 Avant owner
          • s2avant95M
            • 1217
            right i'm going for it this afternoon. if you dont hear from me i'm probably stuck in the car being strangled by some carbon trim..
            Tim
            • s2avant95M
              • 1217
              ok, managed to do the rear doors and the frpnt doors yesterday afternoon. going to tackle the glove box this afternoon, will i need to dismantle the glove box to gain access to the rear of the trim? any tips that will save my knuckles would be appreciated.
              Tim
              • curlyks2
                • 1069
                Found myself in this same position in an old MGB GT V8 a few weeks back... but on the drivers side, so the steering wheel was in the way too.
                *Ouch*
                Ck.
                Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
                • nos
                  • 93
                  What about the trim on the dashboard with air bag on the passenger side?How do you take that one off?
                    Anybody seen an S2 or RS2 with passenger airbag ?
                    I only thought there was an option for drivers airbag...
                    Anybody else ?
                    Paul
                      In you saying that Paul looked what just popped up on another thread
                        Huuuuhhhhhhhhhh - something new everyday as they say...........
                        • nos
                          • 93
                          It is an airbag on both side to me.....
