Battery warning as shift light
  • giorgioS2
    • Oct 2006
    • 102
    • Country: Chile
    Hello, I've seen a couple of videos where they've manage to use the battery warning from the dash board as a shift light, how can I do this ???
    Ex:
    Cheers,
    Giorgio.
  • maddagent
    • Nov 2006
    • 136
    • Home: Northern Ireland
    its not the battery light its the roof opening / closing light as used on the cabriolet.
    I'd imagine its just an empty bulb holder on an S2. looks like they've stuck the shift light bulb into it.
    • prj
      • Mar 2010
      • 6308
      It's very easy.
      The signal to the speedo is analog.
      Just tap that signal and once the voltage is over a certain amount activate the light...
      Can even use a simple potentiometer to make it adjustable.
      • goodall
        • Jul 2008
        • 810
        Originally posted by prj
        It's very easy.
        But not the speedo that turn son shift light its the tacho, which is normally digital with the frequency relating to the rpm
        • andyg plym
          • Nov 2006
          • 4646
          i have shift lights on my s2 super touring audi style. i tapped it into the blue and green wire on the rear of the rev counter
          • prj
            • Mar 2010
            • 6308
            Yeah sorry, I meant tacho (actually instrument cluster...).
            If it's digital just use a DAC, they are cheap...
            Either way, this is extremely easy to do.
