From driver only airbag dashboard to double airbag dashboard on S2 Coupe ABY
  • Audi-Porsche Avant RS2
    • Sep 2008
    • 1041
    • Country: Italy
    Hello friends, I want change the dashboard of mine S2 Coupe ABY that is with only driver airbag with one with also passenger airbag, what I need and what I must know for do it? Sure I need the correct dashboard with also Climatronic temperature sensor on it, driver and passenger airbag, passenger glove box, front door cards and for airbag ecu?
    Passenger glove box is different from early RS2 to last RS2, is right?
    Also for S2 is the same?
    Dashboard from Coupe, Avant, Limo and Cabrio are the same or not?
    Thanks a lot!
    Bye
    Alessio
    My life and my loves
    Audi S6 C4 ABT Avant
    Audi S2 Coupe ABY
    Audi S2 Avant
    Audi Cabriolet 2.0E
    • Sep 2008
    • 1041
    • Country: Italy
    No one have change it?
    Alessio
    Audi S2 Coupe ABY
    Audi S2 Avant
    Audi Cabriolet 2.0E
      • Sep 2008
      • 1041
      • Country: Italy
      Audi S2 Coupe ABY
      Audi S2 Avant
      Audi Cabriolet 2.0E
      • Kryptonite
        • Aug 2010
        • 63
        dashboards are all the same coupe/cabrio/avant/limo! I have changed my old (S2 3B) dashboard with an double airbag. It fits plug and play
        Yes the passenger glove box from the old one is different to the new one.
        • Skull
          • 3506
          • Country: Slovenia
          all dashboards fit to all b3 and b4 cars. but...
          to install the double airbag dash you need the parts from it, including the heavy golden brackets, and also the air ducts!, because of the airbag.
          also, you need matching door cards, for the front doors.
          p.s.: i belive all the lhd double airbag dashboards have the grille on top for the klimatronic sensor. with cars with no klimatronic, it is just the grille, no sensor inside. but if the dash has no grille, it is easy to drill a hole for it, as the hole is marked...
          Audi Quattro WR
            • Sep 2008
            • 1041
            • Country: Italy
            Hello Skull, thanks a lot!
            Sure I must change dashboard and I will buy one complete with all parts, I need also a passenger airbag with carbon trim and front door cards, are front door cards for coupe ABY with passenger airbag the same for all years or not?
            I know that change something between 1994 and 1995 dashboard with double airbag, but what? Passenger glove box only or more?
            Thanks a lot!
            Bye
            Alessio
            Audi S2 Coupe ABY
            Audi S2 Avant
            Audi Cabriolet 2.0E
            • Skull
              • 3506
              • Country: Slovenia
              there is only one type of passenger side airbag type dashboard AFAIK.
              there is also only one version of the passenger side airbag door cards.
              the passenger side airbag was available since middle 1994...
              Audi Quattro WR
                • Sep 2008
                • 1041
                • Country: Italy
                For example Tots sell 1994 and 1995 dashboard, why? I know sure that change passenger glovebox because on mine S2 Avant passenger glovebox is different from mine RS2, the glovebox handle is different.
                Alessio
                Audi S2 Coupe ABY
                Audi S2 Avant
                Audi Cabriolet 2.0E
                • Wolfgang
                  • Mar 2006
                  • 250
                  hey guys,
                  there is a big difference in both versions.
                  the first version is between 1993 and 1994.
                  the second version is between 1994 and 1996.
                  differences are a lot:
                  glove box is completely different, box underneath the steering wheel is different, for example the cars til 94 don´t have a box underneath the steering wheel. the cars from 94 on have a box there..
                  also the complete rear-side of the dashboard is changend, although the passenger side airbags are totally different and not changeable.
                  for example do you need to weld brackets in your early car without passengerside airbag when you´re using a version until 1994.
                  if you´re using a version from 94 on you don´t have to weld brackets in your car.
                  if you want to go for a new dashboard, use the model-year 95 version on.
                  PS: you´ve got a pm
                  S2 Coupe ABY
                  S2 Sedan
                  S6 20V Avant
                  www.audis2.de
                  • Skull
                    • 3506
                    • Country: Slovenia
                    wolfgang: which version is this?
                    Audi Quattro WR
                    • veneto rs2
                      • Jun 2006
                      • 1022
                      • Country: Veneto
                      That looks to me the same dash of my 1995 RS2 and 1997 Cabriolet 8G.
                      I must thoug say that I found few differences on a 1994 RS2 (double airbag) with 4 spokes steering wheel that I drove once, and mine.
                      Can't recall what it was but I believe they're defenetely different underneath the sterering wheel and in the gloves box no idea about the dash itself.
                      I found this picture and I believe it's the one I'm talking about:
                      Stefano
                      http://www.audisportclub.com/
                        • Sep 2008
                        • 1041
                        • Country: Italy
                        Last model dashboard is the better one I think and is the one that have my RS2 that is a my 1995, my S2 Avant have the first model with double airbag I think and so I will chech the difference between them and post here.
                        Thanks a lot friends!
                        Alessio
                        Audi S2 Coupe ABY
                        Audi S2 Avant
                        Audi Cabriolet 2.0E
                          • Sep 2008
                          • 1041
                          • Country: Italy
                          This is the version without passenger airbag like my S2 Coupe ABY, only driver airbag, but there are also two different versions with double airbag.
                          This is my RS2 and is the last version double airbag I think
                          This is a S2 Avant and is the first version double airbag I think
                          Today I try to take some pictures from my S2 Avant that is a first model double airbag dashboard I think.
                          RS2 in your picture Stefano is a model without passenger airbag, driver airbag only like my S2 Coupe ABY and also front door cards are different from model with driver only airbag and model with double airbag.
                          Now I don't know if door cards change also from model with fist double airbag dashboard and last double airbag dashboard.
                          Thanks!
                          Alessio
                          Audi S2 Coupe ABY
                          Audi S2 Avant
                          Audi Cabriolet 2.0E
                          • Skull
                            • 3506
                            • Country: Slovenia
                            This dash is a normal dash, with no airbag, the same for all b3 and b4 cars (from 1986 ->)
                            Audi Quattro WR
                            • Skull
                              • 3506
                              • Country: Slovenia
                              alessio: i dont se a difference in the dashboards in the 2 pics you posted...?
                              Audi Quattro WR
