Ignition Switch
  • 205gti
    • Jul 2010
    • 56
    • Country: Jersey
    Ignition Switch
    At the moment my headunit only comes on/goes off when I turn it on/off manually. Is there anywhere I can easily get a feed from the ignition so it works on the key? I'd also like to connect my boost guage to it.
  • irishs2
    • Apr 2009
    • 2455
    When I fitted my radio and boost gauge, I used the very light red wire on the ignition switch. Thats the 12V switched. On switching off the engine the radio/boost gauge lights stays on until I take the key out of the igniton.
    Eric
    95 S2 Avant under rebuild.
    • 205gti
      • Jul 2010
      • 56
      • Country: Jersey
      Thanks that's just what i'm looking for.
      • jade
        • Jan 2005
        • 1811
        • Home: New Zealand Current: Spain
        Use it to fit a relay, ignition switches are weak, do not over load it !
        RS 2 580HP
