RS2 glassroof conversion
  • wowow
    • 123
    • Country: Hong Kong
    I heard about the glassroof option on later years S2 and how the mechanism is a bit different between the steelroof and glassroof because of the sliding shade. Say I can live without the shade, can I just replace the steel roof with the glassroof ? If so, is the glass roof even available ?
    ________________
    RS2-95
  • Andriux
    • Feb 2009
    • 62
    • Home: Lithuania Current: United Kingdom
    glass you can fit from S2 coupe :
    mechanism is the same as metal sunroof,(i can check it if you want) but how you told, are same diferences between shades, but, ithink its possible make one from two
    • wowow
      • 123
      But other threads said the mechanism is different
      ________________
      RS2-95
      • djh
        • Jun 2011
        • 1622
        • Home: United States Current: United Kingdom
        has anyone actually tried this?
        • mayhemg77
          • Nov 2007
          • 106
          i have changed my sunroof from metal to glass, straight swap, i used my original mechanism tho as the wiring was different but the mechanism fitted the glass roof and works perfectly
          rgrds
          graeme
          • Acidburn
            • 13459
            what about a coupe sunroof panel into an avant?
            • aRtiS
              • Nov 2008
              • 989
              • Country: Latvia
              I would be interested to sun roof for my RS2 too. Ideas, solutions, possibilities
              Audi RS2 600 hp
              Audi S2 1200 hp
              MB 230E '83
              https://www.facebook.com/ventracing.lv/
              • Acidburn
                • 13459
                anyone on here who has both a coupe and avant who could measure the dimensions of the sunroof opening.
                  Read post 2
                  Having had a glass sunroof I prefer the metal.
                  I would like to retro fit the pre select though
                    I did that yesterday after having the motor & panel I got off Pete about a year ago!
                    I made up a new loom for it with the right connectors its only 3 wires, virtually plug & play
                    • Acidburn
                      • 13459
                      lmao finally, and I need to remember everything for monday.
                      I keep finding them motors and panels all over the place, i've currently got 6 I can put my hands on within 10 mins
