Heater Matrix
  • gripper
    • Jun 2008
    • 1156
    Originally posted by LHD_Kid
    gripper, how was the job to do, did you do it yourself?
    My mechanic said it was a straight forward job (but he would say that because hes already done his own) !
    He had more problems with my alarm stuff !
    Got mine from quattro corner but its still not right
    Alex or Rusty ? Can I adjust the main flap (hot to cold) WITHOUT taking the dash out again ? This is the my last hope at trying to get some REAL heat into the car !
    For what this cost me so far I could have bought an S2
    • Pat D
      • Dec 2011
      • 748
      • Country: Australia
      I got the one from Quattro corner as well, there was something a little different with it and it didn't sit in perfectly but was good enough. I'm not at home atm and can't remember what brand it was.
      Since you're doing a fairly big job, I would be prepared to re-do the foam on the internal flaps in the airbox as well. They will most likely be deteriorated and crumbling to bits as they usually do with age. The big flap separating cold and hot air has large holes beneath the foam, and once the foam falls off the hot/cold air separation won't work well.
      ABY S2 stroker (work in progress)
      B5 1.8T quattro
      B4 2.3 (decommissioned)
        It just needs one of the corners re profiling with a file, then it's sits perfectly.
        • LHD_Kid
          • May 2006
          • 3697
          OK, so I will give Pete a call - does anyone know for sure if LHD / RHD are the same?
            I'd say that they're not because of the way the pipes exit the unit but best check...
            • Monkeymagic
              • Mar 2012
              • 3419
              I did my brothers coupe 2 and a bit years ago. Took all day but taking our time and tieded up while there.
              I got a genuine valeo unit as they are in Redditch. It even came with the foam to stop vibration. From memory it was about 40 quid.
