Autocheck fuel calibration
    I've done the fule calibration using the guide on s2central My only issue now is that the autocheck comes up with a fuel pump and a warning when then range still says there's 50+ miles to go! Anything I've missed that could cause this?
    You can try adjusting the gauge, which will move the needle to where you want it, and also affect when the autocheck warning bleeps at you
      I've adjusted it and the warning sounded at just under 1/4 tank!
        ok so adjust it so the needle sits where you want it to with 50 miles remaining. The autocheck and guage reading are interlinked. You nede to match them to what the trip computer is saying.
          I've done that as per the instructions but I'll have to do some fiddling, as it's a little annoying.
