Urs4 strange computer readings
  • bluequattro
    • 2960
    S I replaced the clocks due to non working and peeling speedo
    New speedo etc reads fine but computer says no!
    Average speed has read at above 80mph when i was being good and staying under 60
    Boost is saying 0.5 at Rickover, going up to 1.8 under WOT
    Mpg reads 9.9 ish when tootling at 40, open it up and mpg goes upto 18 or more!
    Driving me nuts!
    Fuel consumption was 18 driven hard,22 ish normal driving
    Any thoughts please?
  • AndyP
    • 6049
    I seem to remember that there are some tiny switches on the back of the clocks so they can be used on different cars, make sure these are all set the same as your old clocks.
      Agree (with the potential issue/solution). Bluequattro, have a read on this (for the general idea):
      • bluequattro
        • 2960
        I checked this to make sure same as before, maybe I didn't slide quite to the right place
        Does the s4 have the same calibration system as s2?
        I've just read s2 central guide on setting fuel gauge
          Did you look at the link I provided and scroll to its bottom, re: calibration?
          • xiancorp
            • Aug 2006
            • 1
            By the numbers you get, it sounds like you have metric settings in the computer..
            50mph=80kph
            Boost is 1,8 Bar (1atmospheric plus boost)
            9.9 L/100km fuel consumption
            Don't know if there is a fix though..
            '92 Audi S4 2,2 saloon
            • ManiacuV6
              • Dec 2009
              • 458
              • Country: Romania
              You need to change the coding plug. IS more like a PCB .
              AND check the switches . You have one or two switches for petrol/diesel and Europe / Uk/ USA .
              Audi S4 2.2T 5 spd 1992 for parts
              AUDI A4 1.9TDI daily use
              Audi 80 Quattro 2.0 16V (ACE) aka Competition
                Trip Computer Coding Plug Information
                For Euro units (kph, L/100km, boost in BAR, etc), you need this 443919100D coding plug (photo below).
                More coding plug info:
