Dashboard doesn't need to come out but all the centre consol does. It's quite a big job to take it out without any damage at all.
you can cut it near the consol/tunnel area which makes the job easier.
Lazy git Mr Smith, can tell you only pull them to pieces these days, not put them back together
Mr Seaton where did you think the leak was coming from in the first place?
Tonks4x4 - The Land Rover Specialist
I've never cut one out myself. Being a meticulous professional i've always taken the long route but i know some who've done an ok job with the snippers.
As you're aware, taking out the carpet and re-fitting it properly is a far bigger job than it sounds.
Morning Me T. Originally I thought that the water was getting in through the bonnet release cable grommet. Which I sealed up. However the water is still getting in. I've checked the sunroof drainage, which were clear.
Then I read a post on here about someone's coupe having a leak which sounds by all accounts the same as mine, they've fitted a new door seal, which appeared to sort this issue out.
I wanted to take the carpet out, so that I can dry it and also make sure the leak is sorted.
