Anyone else have this problem with the coupe boot trim?
    You've done it now!
      Just looking closer at mine, the screws aren't in the centre of the slots and they're not offset by the same amount in the same direction either
      • Bowie69
        • Nov 2013
        • 2676
        I can't tell where mine are, there's too much mastic in there
        • Rikki Kitto
          • Feb 2010
          • 6276
          Originally posted by Rikki Kitto
          I've never even seen this part on my car Put me down for one please
          Still have the kit and try find the plastic
          • johne
            • Apr 2007
            • 1406
            Originally posted by Error404
            This bit is definitely a source of leaks. I managed to get an undamaged one and sealed it better with some little rubber washers, windscreen mastic and stainless cap-heads. Dry now
            It's not sealing to the plastic trim that matters, it's sealing the screwthreads in the steel panel underneath that counts as the water drains along the steel channel and leaking around the threads of the self tappers through the steel is where the water gets in.
            John
            • Bowie69
              • Nov 2013
              • 2676
              Originally there would be a washer under the large headed machine screw (mine was missing the washers), and then under the trim there would be a seal, which looks on the parts catalog to just be a rubber (I assume) washer.
              If the seal does it's job, then all would be well, as the water wouldn't get to the threads of the bolt, but have to say mastic does a great job for sealing both the trim to the body and the screw to the threads.
              Part 33 on here: http://www.partscats.info/audi/en/?i...rent_id=536814
              Mine was also missing the seals.... well safe to say I won't use that body shop again
              I used these bolts to replace the rusty ones I removed (one with a drill(!)):
              http://www.ebay.co.uk/itm/3907294608...84.m1439.l2649
              Good sized head so no real need for a washer, closest to factory spec I could find.
