Clean the Plastic Screen of the Instrument Console ?
This is a sticky topic.
    Is there a way to 'polish' and clean / clear the scratches on the plastic 'glass' of the speedo and rev counter instrument console of the S2 ?
    Thanks.
  • irishs2
    • Apr 2009
    • 2455
    Seems to be possible, I remember seeing this ages ago
    I'm working on replacing all the lights and replacing some other electronic parts in my RS2. Meanwhile the instrument cluster was removed from the dashboard to replace and solder some lights there. Of course I wouldn't be a detailer if I didn't attack the parts with our detailing experience...
    Eric
    95 S2 Avant under rebuild.
      Is there a way to 'polish' and clean / clear the scratches on the plastic 'glass' of the speedo and rev counter instrument console of the S2 ? Thanks.
      I have made my 93 UrS4 Instrument cluster clear plastic look much better with this:
        Thanks for replies.
        • gavs20v
          • Sep 2004
          • 3057
          Halfords have a plastic lense polishing kit I
          Used on my bike headlights. Made a world of difference
          S2 Cabriolet.........
          • Bowie69
            • Nov 2013
            • 2676
            T-cut followed by car polish will do it too.
              Good thread. I need to do this before I put my dash back in
              • Wrath
                • Jan 2011
                • 779
                I would do like the linky, Menzerna PF2500 but then I would go SF4000 , same method when you do headlight if they are plastic... but then you start with wetsanding discs that are soft and rotating machine and spray with water that has a drop of waxshampo or something similair to it, start of with 500-1000-1500-2000 and the PF2500 then SF4000 and some sealing wax looks almost brand new when your done, take about 20-30minutes a piece.
                1995 Audi S6 - AAN (~350hp)
                2008 BMW 530xd (235hp)
                2011 KTM 990 SMR - custom tuned (120whp)
                • John.
                  • 2615
                  Yup, works for me too.
                    • 4754
                    It's very satisfying once it's done. I haven't had many binacles out but when I have I use autoglym super resin polish or 3M finesse-it followed by 3M Ultrafina SE. You can't make a sows purse look good but you will make a goog binnacle look like new. Do the same with plastic indicator lenses and rear lights etc.
                    • s2driveruk
                      • 12696
                      made this a sticky, some good tips in here
                      1992 3b S2 Coupe
                        Forum immortality at last !
                        Thanks for the further replies.
