Bulbs for 1996 S6 Dash??
  • Majorcina
    • Jun 2013
    • 1334
    • Country: Montenegro
    #31
    Originally posted by geneandbolly
    TA DAAAAAAA !!!!
    Which one you used?
    • geneandbolly
      • Sep 2013
      • 1356
      i used a mix of 2.0w and 1.2w bulbs. i guess that the bulbs for the backlighting in the climate control unit are different to the dash bulbs?
      1997 Audi S6 - The Purple Helmet!
      • fourringsofhappiness
        • Dec 2013
        • 40
        Greetings,
        I've not had my CC unit apart but with others in the past I have found bulbs working but dark/chroming over which would explain a dimmer illumination? I also like the ashtray bulb as it lights up the cubby underneath.
        • geneandbolly
          • Sep 2013
          • 1356
          does anyone know if the bulbs in the climate control unit are replaceable like the dash ones are?
          • hunker7
            • Mar 2014
            • 3487
            #35
            They are indeed
            '93 Audi UrS4 Avant
            '15 Audi A7 quattro 3.0 TDI
            • geneandbolly
              • Sep 2013
              • 1356
              fab = thanks janis!! could you post a link for where i might be able to buy them please?
              • hunker7
                • Mar 2014
                • 3487
                #37
                They are exactly the same as dash ones
                '93 Audi UrS4 Avant
                • geneandbolly
                  • Sep 2013
                  • 1356
                  awesome!! now, how on earth do i pull the unit out from the fascia panel?
                  • hunker7
                    • Mar 2014
                    • 3487
                    #39
                    Fascia is held on by clips, so use small screwdriver in the side and pop it off, or open ash tray and pull it carefully from the bottom, then 2 bolts are holding it in place Can't miss it.
                    '93 Audi UrS4 Avant
                      • 4754
                      If you get stuck with it Craig just give me a call and i can talk you through it as mine is part dismantled now. You don't want to spoil any of the surrounding plastics.
                      • geneandbolly
                        • Sep 2013
                        • 1356
                        thanks for the information chaps - i'll have a go at it the first dry day we get up here.
                        it could be july at this rate!!
                          • 4754
                          If it's any concillation it's not much better hear.
                          • geneandbolly
                            • Sep 2013
                            • 1356
                            has anyone here fitted new bulbs to the climate control unit? should i use 1.2w or the 2.0w ones?
