How hard is it to fit these in the Coupe
Fiting RS4 B5 recaro in Coupe
Tags: None
I think Greg has one of these in his coupe so I know it is possible. From what I remember though, it didn't lower the seating position much so if you are tall then not likely to help too much.
They are nice seats though....always wished my old a6 had them in it
1992 3b S2 Coupe -
B5 frames are not a direct fit, the frames are wider by approx 30mm.
You would need to get the frames altered or get some Golf 3 Recaro frames to fit them.
They're not that great anyway; much better to get Mitsubishi Evo 8/9 Recaros and fit them on Golf 3 frames.Cheers'en, AndyC
Got the full interior of flea bay at a good price so gonna make it fit
, has anyone fitted the back seats too, hopefully get them in as well
Attached FilesComment
can you not just fit them to the audi 80 frames or is it to save butchering some.
incidently i feel the saloon ones sit lower than the coupe. ill measure but thats how it feels with the aby trim in my saloon compared.Comment
I swapped my 90 subframes onto b5 s4 seats quite easily, can't imagine the rs4 been any different?Comment
So the plan is to get hold of some cheap scabby Coupe' seats, (anyone got any) butcher the frames off them then try to make somat up to fit these. Also how hard is it or is it possible to fit the electric system in so I can adjust them or things might get awkwardComment
I have the trendline seat fitted, which is basically same design as these but had a separate recaro subframe to fit it as I was trying to get some more headroom. Its still a little tight for me even with these seats thoughGreg
