Anyone unfortunate enough to have to remove the carpet is faced with a few issues apart from the ballache of actual removal.
The earliest example will now be 25 years old and a 25 year old Audi carpet is not a pleasure to handle. There seems to be a few layers. The actual carpet itself on a latex ridged backing and then there is a further bitumen type layer @5mm thick which is backed by another layer, lets call that hessian although its probably a membrane of some sort.
This bitumen layer, depending on the environmental conditions either cracks or seperates from the actual carpet. Unfortunately it seems to be rather a lottery as too what falls off where, leaving a carpet with some firmily attached and bare patches elseware. The driver sides seems to suffer most.
So as a replacement is very unlikley and its impossible to effectively patch the bald patches, I was wondering what other have done or whether there is a technique to remove all the bitumen, leaving a rather shapeless carpet but flat on the underside which is preferable to my mind as it leaves the possibility of trying to make up the difference with a layer of something!
Certaintly water appear to effective but perhaps something like dry ice might work. Any thoughts?
Unless of course anyone happens to have a brand new 3B RHD carpet in their loft.
