Collaboration guidelines
This is a sticky topic.
  • prj
    • Mar 2010
    • 6308
    If you want to submit a patch or similar, then the correct way is to branch the github repo, commit your changes and submit a pull request.
    Files attached to random posts of the forum will be ignored. You are free to modify as much as you like and share your modifications, but for them to be incorporated into the main project it must be done the correct OSS way.
  • vwnut8392
    • Jul 2012
    • 418
    Could you please provide an explanation on how to use github? been trying to figure out how to do a pull request for 3 days now to send you a revised XDF file. all these forks and pulls are confusing.
    "The really good drivers got the bugs on the side windows." Walter Röhrl
    • prj
      • Mar 2010
      • 6308
      This is not in the scope of this project. There are enough tutorials online regarding version control.
      • Sonic
        • Jul 2006
        • 5514
        It's nice a simple using the GitHub UI, or you can do it manually with CLI... https://yangsu.github.io/pull-request-tutorial/
        S2Forum.com Administrator
