Logging cables
  • vwnut8392
    • Jul 2012
    • 418
    Logging cables
    One thing i discovered today is that the generic ebay BMW INPA K+D-CAN cables will work with PRJmod data logging. The one i have been using is the one pictured. Also it is obvious that a cheap blue VAG COM 409.1 cable works as well as generation 1 genuine VAG COM cables.
    This gallery has 1 photos.
    "The really good drivers got the bugs on the side windows." Walter Röhrl
  • filip.krticka
    • Sep 2008
    • 170
    • Home: Czech Republic
    It there any way how to make later Hex-V2 (original Ross-tech cabke ) working with Tuner-Pro RT.
    Same question to Winlog?
    My assumption is that I have to buy ELM327 or and olf VAG compatible cable for non CAN cars.
    Thanks
    • prj
      • Mar 2010
      • 6308
      Any KKL cable will work. The K+DCAN cable is also a KKL cable with a CAN addon.
      HEX V2 will not work because there is no pass-through driver anymore. HEX V1 works with the Ross-Tech pass-through driver.
      ELM327 and similar will NOT work.
      Simply search for VAG COM 409.1 on eBay or similar, should be 5$ or less.
      • filip.krticka
        • Sep 2008
        • 170
        Thanks for the explanation prj.
