Hey Guys,
I got PRJs software working.
The only thing left is how to get datalogging working.
I tried winlog and the dash loaded without a problem but it doesn't load the driver file (WinlogM232FastDiag.dll). When i try to load the file it says "Error: This does not appear to be a valid WinLog driver file". Does anybody have solution?
2nd i tried datalogging with Tunerpro. The .adx file loads and i set up the com port. I saw a difference in the baudrate between Tunerpro and Windoes device Manager (187504 to 9600) i tried to match it in the devicemanager but max was 128000 so i changed the baudrate in the definition file. I tried to connect it to the adapter but that didn't work either.
I would like to get it work at least in Winlog.
Adapter is a simple KKL one With usb connector.
A little problem that occured while i tried some stuff in Tunerpro was that the fuelcut Launch control didn't seem to work. I changed the rpm to about 2.5K RPM but it wouldn't cut. The spark cut LC works without a flaw. I couldn't test many things because my car isn't registered yet.
