i seem to be having issues with getting my fueling right. im using 630cc injectors with no latency table data to revert to so i just left that alone instead of guessing what it should be. i have a 3BAR regulator in my car instead of the stock 4BAR. the only tables and constants i have been working with aside from the injector constant is the VE addend, VE multiplier, and VE table. so far i have drastically changed the VE addend by lowering it to 328 and the multiplier to 396. this is a far jump from either the stock BIN or the big turbo BIN and i dont think its right at all. over all im maxed out the top end of the VE table at 255 and still lean and im at 0 on the low end and still too rich at idle. by comparing the 2 BIN's provided by PRJ i figured the changed to the 2 constants shouldnt be this severe. im only running at 22psi right now and i will be raising the car back to its 28psi that i was running when the car was on VEMS. originally this lack of fueling or ability to tune the fueling better is why i switched to VEMS but over all i would rather keep the motronic because it just runs the car so much better. no hardware has changed on the engine from the VEMS other than i took the 1.8T IAT sensor off and put the stock one back on for the motronic.
so do i need to enlarge the VE table more? it doesnt just seem right because what i have is even bigger than the big turbo file technically and that file has way larger injectors and was demanding much more fuel by the looks of it. did i go the wrong way on the VE addend and the VE multiplier? should i add to the VE addend and reduce the VE multiplier? totally lost here so any help is great.
