I made a tuner pro checksum plugin from PRJ's for the 3B ECU's. It works the same identical way as PRJ's does, it detects the chip size to verify if its the motor or boost chip than makes the checksum corrections. You put this DLL in your tuner pro plugin folder than once you open tuner pro and go into your XDF header>Checksums tab>Add checksum button>Select M2.3.2 Tuner Pro Checksum Plug-in for 3B from the drop down>save everything and your ready to go!
The text file attached is not really a text file. it is the DLL plugin file. download the txt file and once you have it change the extension from 3B_M232csum.txt to 3B_M232csum.dll than put the file in your tuner pro plugin directory. This forum does not allow DLL files to be uploaded directly but it does accept what it thinks is a text file
