just wanted to inform everyone that i found a code error in the code for map switching. if you use it it will never switch to the secondary VE table. This is what you can do to fix it. go to hex address 0x4E97, you will find HEX code 75 75 88. replace this with 12 7F F0, save and correct your checksum. now when you map switch you will be using the secondary VE fueling table in the second master map table. i hope PRJ sees this and corrects the issue in the public BIN files on his github repo.
Found a code error for map switching
