M232csum.dll usage
  • -ice-
    • Oct 2011
    • 173
    M232csum.dll usage
    Hi,
    I didn't use the checksum correction so far. But as my tune is nearly finished i tried to use it...
    Copyied the M232csum.dll to the Documents\Tunerpro files\plugins folders. But I don't see it is being loaded from Tuner pro.
    I see in the source code it will properly register with version, name, description, author etc. but it doesn't appear in in my help->plugins list.
    What am I doing wrong? I had something like "you need to set bin size for using the checksum plugin" in mind?!
    Is the DLL really just 8KB big?
    Using win10 and Tuner pro 5.00
    BR,
    Daniel
  • Acki
    • Mar 2014
    • 302
    Check out the prj xdf file - there you find the information for the correction. Easiest way -> open and save the bin file when you have the prj xdf loaded :-)
    • -ice-
      • Oct 2011
      • 173
      Hi Acki,
      doesn‘t work for me (both checksums wrong after saving)
      how can I check this? Does the DLL need to show up in Tuner pro?
      bye
      • Acki
        • Mar 2014
        • 302
        Yes must be visible...
        • -ice-
          • Oct 2011
          • 173
          Thanks, got it. I didn‘t activate it in the XDF settings...
          must be done like in your screen.
          The plug-in in general WON‘T show up in the tuner pro form help->plugins.
          checksum is then automatically corrected for both chips with saving the bins.
          bye
