Hi all, ive a 3b to prj mod with tfsi cop, under fool boost and High RPM my UBATT drops to 12,5. Other than that the car runs well. Have you also noticed this? I tried new regulator, battery is fine and charged, in cruising UBATT from 13,2 to 13,7
Battery Voltage
This suggests to me an issue with where and how UBATT is measured. The only way to be certain of your real battery voltage is to put a quality voltmeter connected directly to the battery terminals.
I don't believe you have a problem; this is the consequence of measuring voltage on wires connected to the battery carrying varying currents that change with load and RPM.
