There’s more than one way to skin a cat. This is my method.
The aim is to fit my 8.75” components into the doors of my S2. However, this method can be used for smaller speakers and on the other cars of the series 3 range. All the doorcards are nice and flat with the pockets removed, making life quite easy when it comes to doorbuilds.
My requirements:
Fibreglass resin and catalyst
1” Birch ply
12mm Birch ply
Fleece
Easy sand filler
Bamboo chopsticks
Hot glue gun
Staple gun
Router
Jigsaw
Stanley knife
Drill
Dremel
Sanding paper
My existing doorcards look a mess in the above pic. I did already have the speakers mounted on the doorcards in temporary builds. Now I’m happy with the positioning, it’s time to build permanent enclosures for them.
The hole in the card allows the loudspeakers to vent into the door, using it as an enclosure. Whether or not you need to do this will depend on the loudspeakers you use. You need to check the optimum enclosure volume for your drivers.
Ignore the circular cut in the pocket (which was made to accommodate the old builds) but look at the parallel cut. I want to remove the front of the door pocket to incorporate it into my builds. The Dremel comes in handy here.
You could remove the whole door pocket and use it in the build, or even dispose of it completely. The mounting area for the pockets is completely flat so you could easily build new pockets. This is something I did in my Audi 90.
My requirements:
1” Birch ply
12mm Birch ply
Fleece
Easy sand filler
Bamboo chopsticks
Hot glue gun
Staple gun
Router
Jigsaw
Stanley knife
Drill
Dremel
Sanding paper
