Hi
Im trying to get to the bottom of my p*ss poor radio reception – its never worked and I can see from an old post by the previous owner that Girlracer too had problems which never got sorted out. Been reading up on previous posts again re the usual detached white wire to finally try to crack this problem! But cant find all the answers!
I installed one of the aftermarket in line boosters a while ago that cost about £9 off ebay – and it never made a difference! Wired up correctly as far as I can tell to a switched 12v source – but in this post here it mentions making sure to “avoid amplifying the booster and the aerial” when wiring these units in - which it is possible that I have done.
Additionally, at the aerial end its always puzzled my that the amplifier base on the car has a metal ring around it – non of my other two coupes had this and I cant say Ive noticed it on others. Would this make it either a later / after market or even a Vauxhall base? Reason is that there’s also mention of later bases sending the 12v down the aerial cable itself and not separately down the illusive white wire. (I need to check again but Im not 100% sure if mine has a wire in that respect).
Finally does anyone know it the inline booster will work and provide good reception if the aerial base amplifier is burnt out? I would’ve thought it should as the aerial is in effect just being amplified at the other end i.e at the head unit, but have heard that it might somehow!
There's been some pretty.. erm.. inventive (!!) wiring carried out in the past - original ISO block is long gone & I coudlnt locate the white wire. Its also possible that the aerial cable itself is disconnected somewhere I cant see at the moment – but all thoughts welcome!
Paul
Paul
it's off a 98 ish vectra.i even screwed the original aerial into it.
