Delta System
  • jmachray
    • Oct 2007
    • 7
    Delta System
    I have a A6 Avant fitted with the delta radio system the trouble I have is that the rear door speakers or the igintion feed does not work,As I have just bought this car
    I think the last owner might have had a car phone or ipod fitted.So what would like help with is how do i get the unit out of the car.
  • john881000
    • May 2004
    • 598
    radio removal
    Hiya mate
    halfrauds/motorworld etc sell the radio keys to remove radio.........2 slots on radio base
    can be a tight fit
    gently use finger in casset slot to remove radio after keys insertated
    might be plug on top not secure in radio( either long black one or a small yellow/green plug.................depending when they did plug change over)
    this is a start
    hope usefull
    cheers
    john
    • jmachray
      • Oct 2007
      • 7
      Thanks John 881000,will try to get key tomorrow and try to remove it
      • jmachray
        • Oct 2007
        • 7
        After what you said about slots in bottom of radio, had a look and cut two stips of metal to fit can now remove radio! will now be able to check wiring and find fault?
