Finally the Navi project is underway In over my head?
This is what i bought:
* RNS-E unit with GPS antenna
* CAN-BUS simulator fra ebay.de http://cgi.ebay.de/CAN-BUS-Simulator...QQcmdZViewItem
* Extra center console from the bay (in case I screw it completely up)
* Dremel multitool
* Epoxy glue
* Carbon vinyl to cover up gaps etc in the end
* Extra switches for adaption
Need:
Plastic panel which is as wide as the console
Before:
The goal
New frame:
GALA signal
07.03.08:Cut the console down with the dremel tool, and moved (and glued back together) the switchpanel down into the DIN area. Located GALA in the ISO plug.
* Dremel multitool
* Epoxy glue
Need:
Before:
The goal
New frame:
GALA signal
