B6 A4 after market Head unit install?
  • Nj
    • Jan 2007
    • 3420
    • Home: Scotland Current: Finland
    right lads.. I have a single DIN Chorus cassette head unit in my a4. I took it out and was going to pop in a cheap Nikai (maplins special) head unit just cos it has CD, Line In and SD card. It's odd though cos I can't find a switched live on the power block. I've been in there with a multimeter and there's a permanent live but no switch. So how the hell does the existing head unit have a switch? To be fair it doesn't turn off when the ignition's off. You need to turn off the ignition and remove the key. hmmmm. Is there an autoleads ISO adapter I should be using? I don't want to keep the power permanently connected. I spliced the live and switched live together to give permanent 12v but even with the facia off I could hear an intermittent popping through the speakers, suggesting there's too much going on there and I'd be seeing a flat battery quickly.
    And Do I need to think about a PC5-52 amplified aerial?
    The Autoleads website seems to suggest a PC9-401 although the chorus unit isn't really listed anywhere for my year of car. Aww man this is confusing.
    Oh yeah... what the hell's this? Is it some kind of mobile aerial? It's hanging down at the passenger side of the dash. Looks like it used to stick somewhere.
    cheers
    1990 CQ20v
  • Fat Audi 80
    • 10547
    Not sure on the head unit but that is deffo the aerial for a car phone kit.
    Cheers,
    Steve
    The Perfectionist
    • Nj
      • Jan 2007
      • 3420
      cheers Steve. I had a wee look again after posting that and i should have looked closer to start with. it's an aerial and tax disc holder in one. or used to be anyway. I need to find the actual car kit and see if it's of an use and probably get rid of it.
      damn the weird wiring though.....
      1990 CQ20v
      • shark_90
        • 1475
        B6 A4 you say? My speciality
        You won't find a switched live because there isn't one. The radio is controlled by signalling on the CAN-BUS. If you want a switched live then you will find one on fuse 5.
        1994 Audi S2 Avant - in pieces
        2006 Skoda Octavia vRS 2.0TFSi - goes fast
        1985 Audi 90 quattro - is wet
        Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
        • M_GORDON
          • Oct 2008
          • 1295
          • Home: Isle of Man Current: Vatican City State
          I don´t understand yet why you want put this radio...
          photobucket SUCKS
          • Nj
            • Jan 2007
            • 3420
            aha. what the fek's a CAN-BUS matey?
            I'm away to ireland tonight but I'll run a switched live from fuse 5 as you say and should all be groovy from there. thanks
            Because I have a cassette head unit there and haven't owned a cassette for many years now. The head unit I have sitting there has CD player, line in and SD card reader so It will be a bit handier. I'll probably pick up an OEM audi CD player soon but I do like to pull the micro SD card out of my phone and bung it in the SD adapter so I can play my tunes in the car too.
            1990 CQ20v
            • M_GORDON
              • Oct 2008
              • 1295
              I have a Kenwood Head unit, it´s only radio receiver and for cassettes.
              I´ve too 10cd´s charger.
              I hate MP3 and with my Head unit I´m very happy
              photobucket SUCKS
              • Nj
                • Jan 2007
                • 3420
                I wouldn't mind so much with the CD changer but i'm just using radio only now, which is pretty useless.
                1990 CQ20v
                • shark_90
                  • 1475
                  No problems mate
                  • Fat Audi 80
                    • 10547
                    Canbus is a way that many devices communicate with each other...
                    The Perfectionist
                    • Taffdan
                      • Aug 2009
                      • 5
                      Guys, I have just bought an 2001 Y plate Audi A4 B6, and want to change my headunit. I have bought the extra ISO adaptor but cant get my Ripspeed DV701 to power up. I have switched the two power leads, and the stereo beeps but does not turn on. Any ideas, before I end up taking it to someone to install for me and cost me even more?
                      Dan
                      • shark_90
                        • 1475
                        Same problem, you need a switched live. Also check the wiring in the harness as you can send +12v to the K-Line which will make diagnostics interesting.
                        I'm an hour away but bring it up to me if you like.
                        • Taffdan
                          • Aug 2009
                          • 5
                          OK how do I create a switched live? Step by step guide would be helpful lol
                          • shark_90
                            • 1475
                            You don't want much do you?
                            Take a wire from fuse 5 as said above. Done.
                            • Taffdan
                              • Aug 2009
                              • 5
                              Can I not join the two wires together to make it work?
