Uprated speakers
  • xgordyx
    • Sep 2006
    • 379
    Uprated speakers
    Hi folks, i'm in need of new speakers for my coupe, front and rear. Been looking through some threads but still unclear of what i need. Basically i'm after some decent quality ones that are relatively simple to fit.
    Gordy
  • Cymru1
    • Sep 2008
    • 436
    BUMP
    As above....but for Avant
    Must be direct replacment, no cutting of metal and door cards, etc
    Love to keep the "factory look".
    Anyone??
    • terrybullwon
      • Mar 2006
      • 8782
      I have some in the doors on the front, i would be willing to swap them out for cash and the door cards and molds
      Chef
      • xgordyx
        • Sep 2006
        • 379
        Thanks for the offer, but just wanting to swap out the stock speakers as they are knackered.
        • dest
          • 4287
          There are loads of threads in the ICE section about it
          • Colesy
            • Feb 2009
            • 2982
            I copied Sonic's speaker thread for the fronts, MB Quart RUA-210 bought from German ebay: http://cgi.ebay.de/MB-Quart-REFERENC...3%3A1|294%3A50
            They fit into the OEM position and the tweeter fits nicely in the small round air vents in the dash more info here:
            Can't fault them myself, I also bought the rears but haven't got around to fitting them yet.
            • FRANK NITTI
              • Mar 2008
              • 107
              Uprated speakers
              Hi I believe the focal 165 a1 are speakers.They come with tweeters and crossover,also check this link ive added for front pocket speakers.Good luck.
              Scopri MyFunGiochi.it, leader nella produzione e vendita di giochi per parchi e arredo urbano. Soluzioni innovative e sicure per rendere gli spazi pubblici divertenti e funzionali.
              This was my boss and I know for a fact if he was around today he would be driving a sick ABY armour plated S2 1500 bhp....
              • FRANK NITTI
                • Mar 2008
                • 107
                Hi I believe the focal 165 a1 are good speakers.They come with tweeters and crossover,also check this link ive added for front pocket speakers.Good luck.
                • d-a-n
                  • Aug 2009
                  • 20
                  Make sure the total height of the speaker is 47mm or less. I have Pioneer TS E 1076 speakers in the dash whihc is running off of a Alpine H/U. Will you amp the fronts because I doubt you'll need much more than these if you're not going to!
                  Might not be what you're looking for but I put this up a while ago on audifans.net
                  • Le S2 Audi
                    • Jul 2009
                    • 3805
                    I had Rockford Fosgate speakers fitted to the front and rear of my coupe.... But it was nearly 10 years ago, and they were a direct fit to the OEM speaker mounts.
                    Except the tiny tweeters that I had mounted On the dash for directional adjustment!
                    Rears are FNP1514 5-1/4" BY 2-7/16" (61.9MM)
                    Fronts are FNX1414 4" BY 2-1/8 (54MM)
                    KAC646X AMP 4 x 50Watt - mounted on the back of the rear seat.
                    Ken
                    New S2 - S8 & RS2 -RS6 Keyrings
