ICE install (regular car, so not an Audi..)
  • lind4hl
    • Jul 2008
    • 2465
    thought i could share my ICE install in the beemer for you, maybe fun to see?? otherwise remove the thread
    i wanted some time away from the rs, but do something, so why not build "little" ICE in another car?
    The car:
    The Spec:
    4x Re SR 10" dual 2 ohm
    1x Orion hcca D5000 (1640w RMS@ 2ohm)
    2batteries
    dual25 mm2 + and - to the amp.
    some Focal/hertz front kit
    Audiovox dvd stereo
    did start on the sub-box a while ago..
    Subs+amp
    started building the box in 22mm MDF
    Test fit
    front finished, gonna screw on the rear later and cover the sides later..
    Started wiring, 6mm2 to each sub. going into a connection so i just need to have 1 cable to the amp.
    When i come home i will go buy more cable and finish the sub-box (needs 12cm longer port also, going upwards)
    then i will mount 1 more battry in the spare wheel well area, and also have the amp down there
    as said, remove if its wrong showing beemer pics here
  • Sonic
    • Jul 2006
    • 5514
    Crikey is that enough subwoofers?! Nice install
    Whats the tool called to cut the circular holes for the woofers? I need to make a subbox myself.
    S2Forum.com Administrator
    • lind4hl
      • Jul 2008
      • 2465
      for now,4 will be enough
      im using an ,ehrm, regular jigsaw to do the holes
      • Sonic
        • Jul 2006
        • 5514
        Must just be me unable to use a jigsaw properly
        • lind4hl
          • Jul 2008
          • 2465
          practice
          • Fat Audi 80
            • 10547
            lol @ sonic and his wayward jigsaw!
            Nice install, show us the rest.
            cheers,
            Steve.
            The Perfectionist
            • lind4hl
              • Jul 2008
              • 2465
              tnx, more pics coming when im working on it..
              • Sonic
                • Jul 2006
                • 5514
                cheers,
                Steve.
                This is why i've had 2 sub's boxed up for the last 8 months - i dont know where to start making a subbox!
                • lind4hl
                  • Jul 2008
                  • 2465
                  Audio system WAS up and running, Started tweaking and after 10min me and my friend heard some weird noise, located it to a sub and took it out, the membrane(?) has got loose from the metal cage
                  but it played like hell those 10min, we expected 145Db with almost no gain, and only a 12cm long port (should be around 34cm) so, i will tweak the port, glue the membrane and then im gonna start buurp again
                  Pictures coming tomorrow, need to get them from my friend first, he held in the photography today
                  EDIT: And this was played with music, no Hz songs..
                  • Acidburn
                    • 13459
                    What music you into?
                    Nice setup and should rattle some windows.
                    • lind4hl
                      • Jul 2008
                      • 2465
                      Mostly Rock, that´s why im going for 4 x10"
                      • Acidburn
                        • 13459
                        Ah ok hence the 10's rather than 12's quicker for fast moving stuff etc.
                        What have you done about the front speakers?
                        • lind4hl
                          • Jul 2008
                          • 2465
                          exactly,
                          the front system are going to be µdimension JR 5 COMP
                          with an µ dimension amp to that
                          • Acidburn
                            • 13459
                            Lol then I take it your spending most of your time fitting the supercharger your ordering for this
                            will be good then
                            • lind4hl
                              • Jul 2008
                              • 2465
                              Dont try to convince me!! aargh. this will have standard engine, for ever
