MDF Speaker Rings
    MDF Speaker Rings
    Anyone on the forum make MDF speaker rings?
  • JP
    • 1858
    Electric hacksaw and a drill is all that's needed.
    Used to make custom speaker pods that way. Make the ring position the angle you want it. Stretch over subwoofer speaker cloth. Impregnate with fiberglass resin and finish molding once hard with body filler. Then retrim with desired cloth/leather/alcantara etc...
    UrS6 Stroker + HTA3586 =
      I live in a flat, no access to use such tools now
      I'm more than capable making sub boxes http://www.s2forum.com/forum/showthread.php?t=9802
      them were the days
      • borderS2
        • Jul 2008
        • 166
        Do you want to convert large speaker box for smaller speakers?
        I am making a pair for a mate. What size internal and ex? What thickness? Pre drilled?
        S2 91 (red standard)
          Yeah got it in one, need to convert a box from 12" to 10"
          Thickness 25mm OD = 12" ID = 9" recess in ring 10.5"
          • borderS2
            • Jul 2008
            • 166
            Rings
            Same as I need to make. I think the thickest we have is 18/19mm. How deep do you want the recess?
            The ones I have planned are 320mm OS, there's enough space on this front panel.
            You want 305mm OS, 229mm IS and a recess in one face to seat the 10" speaker in, 268mm diam recess in centre?
            You want a pair of these?
            I will should be able to get the design done this week but if the CNC router is busy it may have to wait to be cut. Should take less 30 mins for all this and mine.
              I only really need one ring to be honest b
              I dont think i'll need the recess if the wood is 18/19mm then
                Sod it I want he recess
                • borderS2
                  • Jul 2008
                  • 166
                  How deep? and it is for the new speaker to sit in rather than to sit in the hole in the cabinet
                    both I'll sit the speaker in the recess and then put the ring inside the box hole which then sits in a false floor
                    failing that I'll have to dismantel the box and make a new front mdf piece
